OT-replacement baseboard heating elements
Rkh
Trying to match baseboard heating elements like pictured. Ive looked around, but havent found anyplace that
matches-need to add more elements in my utility room? Anybody know where i can get these that would
match?
NOT sure who made those with the unique rounded corners.
Typically, you can buy them as an assembly, cover/trim only, or element only, so if matching is important you could buy cover/trim for the existing ones along with the new complete units so that they would all match.
Or use units from other rooms to match, then replace those such that the design difference was in a different room, or irrelevant. Or all the units in this room could be replaced and those used else where. Jim
Try global industrial.com KCCS-L slotted end cap. Closest one I could find that was rounded for baseboard. On one of the heating forums it was suggested to try a local metal shop for making a duplicate.
Yours looks like my hot water baseboard heaters. And like mentioned they look like slantfin. I buy a lot of stuff from supply house. If you want electric baseboard, supply house might be different.
baseboard heaters
