homesteader1954
my 1070 case starting having problems disengaging the transmission when i push in the clutch. if i push it in and out quickly 5 or 6 times it usually then disengages and i can shift into gear. i heard there is a clutch spool somewhere on this unit that could be the culprit due to sticking and to clean it. can any one tell me where this clutch spool is located? or anything else it could be. it will eventually go into gear if i push in the clutch several times. Last fall it did this for a bit but after doing some cultivating it stopped doing it till plowing snow today.....lots of back and forth clutch work and not noticeable till i had to move a truck and then shift it back into gear. any ideas would be helpful and pictures. Dont have a service manual for it.
