Paul Shuler
I followed some of your guys advice and removed the big square 30 amp fuse and waited a bit and put it back in and everything is as it should be this morning. I do enjoy all the new and fancy stuff on new cars but I find it ridiculous that a computer and a fuse can determine when I might want to use 4wd. I miss the day when you could just lock in your hubs on a bad day and use the shifter in the floor as you needed it. Heck we had a new 77 chevy with a small block 400 and fulltime 4wd and that old truck never failed to go when you needed it. It would either jump you right out of a hole or sink it to the frame in 10 seconds. lol. At least you knew you where big boy stuck and not just a fuse. Thank you all for the help. You saved me once again.
