new narrow front tractor!
oc-18guy
I ran across a new Holland T7.270 with a narrow front that is presumably factory planting celery I assume ,anyways I have no idea how to post a link so if you care to look go to youtube and search new Holland T7.270 trike tractor. hopefully someone smarter than I will post a link , very interesting video though.
Very interesting, if you look close at the front end you can see the original wide front still there, just no tires. Sure is different type of soil they plant celery in, they plant it on muck ground by me, central mi.
Poke here
Here it is:
That is intersting, that tractor sure is odd, I wonder why they can't just use a regular tractor? Thanks for posting.
(quoted from post at 20:03:13 01/12/16) That is intersting, that tractor sure is odd, I wonder why they can't just use a regular tractor? Thanks for posting.
I expect that the tires are part of the ground preparation The tires cover all of the ground with the huge sized-low ground pressure tires. One tire contact instead of fronts followed by rears.
Part of it might be all the rear end weight when they raise the planter. Notice how light the front is with the planter and workers raised. It was good to see the extended platform to get to the tractor seat while the tractor was moving, had me worried.
Oh my gosh! By posting that, you are going to bring out the safety natzies & start all that stuff about how easy it will overturn!!!! :roll:
