MH44 EFI Update Pictures
David G
The new starter gear reduction starter came today. It is a lot smaller diameter, but has a solenoid on it. I will need to relocate the oil filter up about an inch or will have to remove starter to change oil,
no oil in filter right now so will move it.
I copied a left and right picture.
Note, I have not mounted the PS pump yet.
Nice clean looking unit, you should be able to find a shorter filter I would think.
David being a life long mechanic and owner of several massey 44s I certainly admire your workmanship. Who worked out what starter to order. We always just went with one off of a 55 when we build the high compression 44 engines. Looks like you solution would have been better. Some day I want to see the dyno final results. We build some pretty strong engines ou of those 44s.
That's what I was thinking. Shorter filter. Good luck trying to find someone at parts house who will work with you on matching up a filter.
While a shorter filter would be easier to access, you would need a custom funnel or catch basin to remove it and catch the oil. HTH
