(quoted from post at 02:08:44 01/01/16)
At the same time add a timer to cut power from 7:00AM to 7:00PM Mon-Fri. Heat the water for approximately half the $$$.
I keep mine turned up because I hate running out of hot water. And mine is propane with quick recovery.(quoted from post at 18:38:30 12/31/15)(quoted from post at 02:08:44 01/01/16)
Why not just turn the temperature to a less hot setting?
(quoted from post at 21:38:30 12/31/15)(quoted from post at 02:08:44 01/01/16)
(quoted from post at 21:43:55 12/31/15) buickanddeere,
If the larger part of electricity KW spent is within the confines of a home requiring heat, well, then, that does transpose into energy spent within the home.
In summer, perhaps there may be some savings not having heat interior.
D.
(quoted from post at 15:45:44 01/01/16)(quoted from post at 21:38:30 12/31/15)(quoted from post at 02:08:44 01/01/16)
Joking or serious ?
(quoted from post at 14:33:41 01/01/16)(quoted from post at 15:45:44 01/01/16)(quoted from post at 21:38:30 12/31/15)(quoted from post at 02:08:44 01/01/16)
Joking or serious ?
Serious,
Although I think my question has been answered by the posters above. I was thinking that shutting the heater off would result in a less hot water temp, but not in a controlled manner, thus turning the temp to less hot would at least be under control and would make sure the temp would not bet too cold.
(quoted from post at 15:33:41 01/01/16)(quoted from post at 15:45:44 01/01/16)(quoted from post at 21:38:30 12/31/15)(quoted from post at 02:08:44 01/01/16)
Joking or serious ?
Serious,
