Bill from Scotland
Just wanted to check if Im correct, are late 50's early 60's tractors such as Case, JD and International positive earth. When did most trurn to negative earth?
Bill
Bill
(quoted from post at 07:56:08 12/28/15)
I believe all alternators are negative ground?
Paul
While I always find John T's posts interesting, This one just hit me funny, the acronym used for Positive is the same as Piece of Sheet. 6 volt were P.O.S. ground can sure be taken two ways. LOF(quoted from post at 08:42:45 12/28/15) 1) All two cylinder John Deeres and the early New Generation that still used Generators instead of Alternators used the tractors iron frame as a return current path and were commonly referred to as POSITIVE GROUNDED as the batteries POS connected to the tractors iron frame.
2) Many (not all) early tractors of the 30's through 60's or so vintage that were still 6 volt were POS ground but when they started using 12 volts many (not all) changed to NEG ground.
Of course, that has nothing to do with nor any reference or bond to Mother Earth lol Our electrical grid distribution system, however, has its Grounded Neutral conductor indeed bonded to good old Mother Earth.
I have no literature to show all the brands and if they were POS or NEG Ground and what years and models were such, SO THE ABOVE IS ONLY A GENERAL GARDEN VARIETY ANSWER..............Take or leave it at your own risk and peril.
John T
