HELP 60 john deere
DKM
New User
I need help I'm currently repainting my john deere 60 tractor have it all prepped for paint and found that the power steering pump is leaking in the front so it needs to be taken out I was wondering how to take it out is there a way to take out the pump without removal of the radiator or anything please help I cannot find any info on this situation thanks a lot
If you post this down on the John Deere forum, you have a higher chance of finding someone that can help you out.
Ross
I just did that to my 60. There ain't no easy way. Remove the power steering lines, the water pump, upper water pipe from the radiator, fan shroud, steering shaft, radiator, then the power steering pump and fan. The fan is almost imposssible to get off. It has keepers sort of like valve springs and by now it is rusted together. It needs to be disassembled in a press and I broke my hubs and had to by new ones. The seals are replaced with two on each end installed back to back. It also takes about $70.00 worth of gaskets. Have fun.
