kubota L2550 won't start
kubota
New User
I have a Kubota L2550. I changed the fuel filter and have fresh fuel in. The engine cranks but won't start. If I spray starting fluid into the air intake it will run until I quit spraying. I used it last week. It ran for about 30 minutes then suddenly quit. Any suggestions on want to do to get it started?
I have an L225DT. After fuel filter change I have to crack open fuel lines at the injectors and crank until no air bubbles appear. My tractor also has compression release to assist cold weather starting. I use this so engine spins
faster, gets air out of injector lines sooner.
