Battery Charger
JimS
On an automotive battery charger what does a flashing red light mean? ICBMs launched? I assume a steady red means charging?
I have two battery charges with indicating lights, Red is charging and green means fully charged. They will sometimes show that even if it has a bad cell. Some batterys you still can check water levels. They have to be kept full for correct charging. Norm
I would think bad battery/hooked wrong/or set on the wrong voltage... for safty find out before trying to charge it again. It seems like it is trying to get your attention. Good luck and be safe...MTP
I have an old 15 a craftsman. It flashes red when charging and green when finished. The ammeter also indicates how much it's charging.
