CHANGE over
jeffcat
Oh noooo!! The super duper charger that I and a lot of others have praised on here might be gone. The Shumacher charger that worked so nicely and was $19.97 at Wallyworld has changed. {top one} Was in there two days ago and this is now the newer one.{bottom one} I am going to hit a couple of other stores and see if I can pick a couple of spares up before they are gone. New one may be fine but I like the older one. Looks as if the new one does all of the same, just is 2 amp charger. Hurry hurry.
TSC has the 1.5 amp Schumacher for $19.95. I bought one but it doesn't seem to be working. Guess I'll take it out of the box and hook it up, sometime.
The older one has just worked so nice for two years now. I am going to look around though.
I like the "batteryminder" brand as they go into the pulse mode when battery is full. This is the de-sulphate mode. I think that option is worth every penny as the "pulsing" breaks down the sulphate that coats the cells. Northern Hydraulics and ebay has them.
This one goes into the pulse mode too. "cycle mode" Has brought back a couple of marginal lawn tractor batteries.
I would check them out first because that new one is good for batteries up to 300 cca. I have several Schumacher, one Sears which is made by Schumacher and charge 6 and 12 volt batteries. I also have several Deltan battery maintainers.
