What you think about a Ford 1500 Diesel Tractor
edknapp
Ford 1500 Diesel tractor. Runs great. Starts right up
3 point
Will be used for mowing and small 1/2 garden
Ed
There have been reports of NLA or very expensive parts for them. I would spend some time on Messick's site checking parts availability and pricing.
(quoted from post at 05:59:39 11/13/15)
Thanks will do that!
I looked up a injector and a water pump and didn't think it was way out of line
thanks for the heads up
Ed
Is it 4wd? Front axle parts might be hard to find, be sure it is mechanically sound up front.
Fine little tractors just getting older. Nh switched manufacturers a while back, so parts become an issue that way.
Paul
Friend of mine has one, its about impossible to find parts for so he bought one with a bad engine, and one with a bad transmission to use for spare parts. You can usually find one, or two that doesn't work for some reason pretty cheap for spare parts.
(quoted from post at 09:18:37 11/13/15) Friend of mine has one, its about impossible to find parts for so he bought one with a bad engine, and one with a bad transmission to use for spare parts. You can usually find one, or two that doesn't work for some reason pretty cheap for spare parts.
Thanks
Ed
