I'll admit right away I know enough about
electricity to fill a thimble.
So our new heat pump stopped working after
a month. I called the company and they came
out to find that the breaker broke and
nothing was wrong with the heat pump. I was
not at home when all this was going on so I
came home just to find the wires off and
capped because the worker didn't have the
correct breaker. I did not see where the.
Wires went. I got a new tandem breaker just
like the old. I put the red (HOT) wire for
the heat pump at the very top pole and the
ground wire at the very bottom pole. The
center two poles is for the dryer. Again
Hot wire on top and ground below it. Is
this right? Both dryer and heat pump are
working but I question the way I wired it
cause you can see in the picture the
secound tandem breaker down in the picture
goes Red Black Red Black
Picture is loading sideways so the breaker in question is on the left
