Used 24 inch tractor tires
caterpillar guy
I'm looking for a couple of 24 inch rear tractor tires. With or without wheels or rims. The tread is not important as much as the casing being good. They are going to go on a sprayer so needs to be probably 6 or 8 ply or more. Will be carrying about 6,000 LBS at most with part of that on the draw bar.
you could check out wrecking places as the versatile swathers use 11.2x24 tires like that.
Thanks, I have 11-24.5 from the truck. I was hoping to find like a 12-24 or such. I need the flotation of the wider tire with more height. The truck tires won't fit on an implement rim very well.
I have not looked at salvage yards yet. Thought I might get some private sale.
thanks again though. didn't know if some body had some for sale.
Check with good farm tire shops. Lot of front assist tractors used 24" tires on the front and a lot of combines use them on the rear. Maybe even a tractor salvage yard.
AaronSEIA
