Crazy Horse
We have a 1975 Satoh 650G here, Japanese-made small tractor (2200 pounds) with a 3-point class one hitch. I don't expect many here to know these tractors inside out but I suspect that most 3-point systems work the same (or in a similar) way. Haven't had the tractor very long but the 3-point hitch was working (although I think the arms dropped after shutting the tractor down), not sure how well it worked, we never had an implement hooked up to it, but it did lift (with maybe a wee bit of chatter).
So last week I drained out the hydraulic oil, only 5 litres in there. Also cleaned out the metal mesh filter screen. It drained for a couple of days before I got back to refilling it. Started the tractor up today and the 3-point arms would not lift when putting the lever in the lift position.
Any suggestions as to what might be the problem? Maybe an air lock of some kind or someone mentioned the pump maybe losing its prime. Anyways, I appreciate all responses .....
