I got the John Deere 70 gas out to work some this fall. Put it on a 61 foot auger and it ran just fine threw a few thousand bushels of corn. Drove it to the gas tank and partially filled it up with gas that was just delivered. It did have ethanol in it. Just wondered if the new gas from the bulk truck might have been dumped in a close to empty storage tank absorbing the water at the bottom of the tank. Tractor began to run poorly and now won't even start. I have tore the carb down and there were no plugs - all passages are clear. Good spark at plugs. Automatic fuel shut off works just as it should. Maybe I should drain the gas and put in some fresh from town. Any ideas?
