Need to wire onto john Deere 5020
gqjoe
Hi, I purchased a 5020 few years ago and this tractor had this starter relay in if for the 12V start.
I took it out a while back and would like to put it back in but I cannot remember how it hooks up again. Any help would be appreciated!
Typically, when a 24 Volt DEERE is converted to 12 Volts, a "fender mount" starter solenoid is installed that is operated by the ignition switch or starter button, that switches current for the big solenoid on the starter's battery side terminal to it's "S" (start) terminal so the wiring, including neutral safety switch(es) doesn't have to carry the heavy load.
Is this what you removed, or had someone installed a semi-truck style series-parallel switch?
Jim, I didn't take tome to look, would the newer ones that were originally 12 Volts have a an auxiliary solenoid ahead of the main main starter solenoid, do you remember?
Bob
All I can rely to answer your question is the parts catalog as only one 5020's that I know was sold around where I live. This relay is shown and it's not called a kit.
