Compact/utility 4x4 tractor front tires
SHALER
I have a Ford 1510 4x4 small utility tractor, 25 hp or so with a 770 loader. Previous owner had installed car tires on the factory 14 inch front wheels. Rears are the large turf tires. I am ready to install the ‘right’ front tires. Would like to buy R4 lug tires (ie industrial or construction). What size should I be looking for? I would say the wheels are close to 8 inches wide.
(quoted from post at 08:26:20 09/18/15) I have a Ford 1510 4x4 small utility tractor, 25 hp or so with a 770 loader. Previous owner had installed car tires on the factory 14 inch front wheels. Rears are the large turf tires. I am ready to install the ‘right’ front tires. Would like to buy R4 lug tires (ie industrial or construction). What size should I be looking for? I would say the wheels are close to 8 inches wide.
http://www.tractordata.com/farm-tractors/000/5/8/583-ford-1510-dimensions.html
Miller tire (see link). Have bought from them in the past but they are getting a bit pricy.
Another option which may be a bit more reasonable is Freidrich. Sorry you may have to cut and paste this link.
http://www.friedrichtire.com/Home_Page.html
JT
Miller Tire
I got 2 good 24 x 8.50 -14 turf tires to sell cheap. $10.00 each. pic. at Mansfield ohio craigslist under farm & garden look for turf tires.
Not sure how bad that would throw off your 4x4 since by the chart yours calls for 25 x 8.50 -14 which is a little bigger around.
previous owner probably did not want to pay $135.00 each for 6 ply turf tires. They do make an industrial 6 ply for loaders in that size for the same price as 6 ply turf tires. If you are going to use the tractor in the field get the loader tires, if it is for use in your yard you may want the turf tires but they are pretty helpless on side hills and ditch banks.
