i have posted this before in the garden tractor section and thought I would try here also..i recently purchased an x748 and..i need to know what voltages the fuel shutoff operates at..it is a 3 wire system coming from a relay under the dash..one 12guage wire shows 12 volts when key is on,,the 16 guage wire to it shows .43 volts.. and then the ground ..the solenoid gets hot and so do the 12 ga wires when key is left on for about 30 or 40 seconds..does it reduce the voltage somehow when started?..also the alt doesn't charge..its a pancake style alt to describe it the easiest and it is a 2 wire plug in..what excites it to begin charging..thanks for any inputs or thought on this
