bankshotone
New User
My Farmall 350 (not utility) was leaking hyd oil out the tach drive so I removed the pump and replaced the seals, reinstalled the pump, filled reservoir, primed the pump, started the
engine and I have no pressure to speak of, it will lift the fast hitch and the bucket slowly but NOTHING like it was, in order to raise the loader I have to rev the engine up, then it
will go up slowly but as soon as the engine is idled down and the lever is still in the raise position the loader will come back down. Is there a pressure relief valve that could be
stuck in a bypass mode? I am stumped, any suggestions would be greatly appreciated! thanks!!
