Oliver 70 Row Crop Drive Shaft
Erny2u
New User
This tractor needs a 10 spline drive shaft, but I can't take the old one out.. the housing pivots on 2 pins. the pins are about 1" diameter by 4" long and they go thru the tractor frame and align so as to allow the clutch housing to pivot. I have used a micrometer to try and measure the approx shape of this shaft and I input this data on AutoCad and can send you what It looks like... I can't find a vin number or a serial number, all I can find is a number on the motor/6 cylinder engine # D600A619
I have a 70 that's apart right now , so I might
be able to measure things , but I don't
understand what this is . Are you talking about
the trans input shaft ? Or the PTO shaft ?
They are usually threaded. If not, drill and tap
them 1/2" so you can make a puller for them or
use a slide hammer to remove them.
Ross
