off topic -- Low sided dump trailer
ezkubota
New User
I'm looking for a 16ft low to the ground dump trailer with about 82/83 inches between the fenders with removable sides.
Basically a an equipment trailer that dumps to haul an old tractor, car or what ever. kind of a do everything trailer
can find 7 x 14 or 7 x 16 but the sides are too high to put a car on. and don't want to crawl out the window
Neighbor has a 14k cornpro dump. He hauls his tractor in it. Not sure how long it is. I think it 14 ft.
One down side to his dump is the rear axles are set back too far. When I load his trailer with his horse poo, I have to put the straw towards the front of trailer and the heavy stuff over the wheels or I'll overload the hitch.
Have a 10 ft 10k dump and I can carry about the same weight as he can. My wheels are spaced like they should be.
If you are looking for a 16 ft dump, a good chance you will be getting something bigger than a 14k. You may want a goose-neck or 5th wheel dump.
My boss has a low sided 16 foot dump trailer and we can haul his Massey 65 no problem. Also haul Case 95XT and the other day had 8 yards of bark mulch with 2x10 side boards. We also carry our concrete forms but the 95XT makes the F350 grunt on the hills!
I would advise that you get both a dump and another for your other stuff. In my experience, when you make an adaptable or multi-use trailer you end up with one that does neither job well. Your much better off with 2 trailers that fo each job well.
