I have a MF205, and the PTO seal is a two-part seal. I pulled the shaft out, and replaced the outer part of the seal with one that was close in dimension, but the metal sleeve part of the seal, I could not find, so I re-used it. My leak is nearly the same. Does anyone know where I can find this 2-part seal (3281561M1)? Alternatively, does anyone know a substitution for these parts?
This might be your answer. http://frugalmechanic.com/auto-part/skf-15840
If you look down on the page it gives a bunch of cross references. You should be able to get one of those at a parts store.
