Junk Yard Dog
Allan in NE
I go thru grapple heads like others change socks.
If I'm not stacking hay, I'm feeding it, so they get a lot of hard use every day.
Salvage yard dinged me $750 for this one. Needs a couple of teeth and one tine brace. Let's see how long this one lasts. :>)
Allan
It looks nice to have, but wouldn't a bale spear work for you? It would lighten the front of the tractor by a few hundred pounds! Nice pic, was just wondering.
Just not practical. Ever try to pick up a broken bale with a spear or grab one sideways?
'Sides, I raise alfalfa. Doubt if a spear would last 20 minutes with these bales. They're heavy.
Allan
Man alive.... That looks JUST like the grapple on my old Farmhand loader?!!? I am planning on putting it on my backhoe!! ;)
<image src="http://forums.yesterdaystractors.com/photos/mvphoto26280.jpg"/>
They don't do well with broken bales, and only somewhat better sticking them from the side, but the WILL hold up to heavy bales. I've moved 1000's of high moisture bales with mine. Any of the good ones will have forged tines, typically rated at 2200# - 2500# each.
Well, I don't make the ton bales like a lot of guys do, but they are big enough that ya better have a good hold when you to throwin' 'em around.
Allan
I know a person wants to run what he is comfortable with, but with the bucket off and the forks on, you will bring the bale closer to the front of the tractor, making less wear on the front end with those heavy bales.
I've handled thousands of heavy alfalfa bales with two spears, the factory ones, and have never had a single problem. But again, sometimes it's what you are comfortable with. Bob
Ever thought about going to something like this? You can raise it up then tilt the bale down so it's being carried down under the loader,right close to the grille and front axle. It's a whole bunch easier on spindles and you don't have so much trouble with traction either.
RRlund,
Does that grapple pivot, so as to hold the bale in a horizontal rather than vertical mode. Like how did you stack the 3rd or top tier in the photo? Thanks, Tom
It's in the up position in the picture like when the bucket is tipped up. It tilts all the way down like dumping the bucket. To stack the top row,I just squeeze the bale from the outside with it sitting just like it's stacked. I can grab them in any direction. It even works nice for cleaning out a feeder. Just open it up,tip it down,use a little down pressure,keep squeezing and raising,working down around the loose stuff and you can lift a whole wad of loose hay out then dump it in the barn for bedding or whatever.
The good forks Will out last anything that tractor can lift. I lift 2 1500lbs bales at atime,1 fork in each bale and have yet to break one. is true a grapple can handle broken bales and a fork can't. But with a fork from the end you will almost never break a bale. We load from the side, 2 bales at a time on the semi(pipe style), and spear in at a bit of a down angle with no problems. I have used grapple and forks and will only go back to grapple in winter when I have to push snow as well. Once you get used to forks it is way faster and you don't break the bales when one slides out of the grapple.
just my $.02
If you don't have a quick attach bucket the grapple claw is the easier way out. In my meager opinion a loader isn't fully functional if it doesn't have grapple claw capabilities.
