farmall m front wheels
butch49
I have a farmall m 1943/44 the wheels are the old style. can you replace them with the newer hubs and wheels, I have split one wheel and another one is going the bolts don't hold .\
carl
montana
What do you mean old style two types were used adjustable that used bolts to fasten to the hubs other used bolt and clamp and they are not interchangeable so when replacing you need to get the correct one.
(quoted from post at 21:04:48 08/17/15) I have a farmall m 1943/44 the wheels are the old style. can you replace them with the newer hubs and wheels, I have split one wheel and another one is going the bolts don't hold .
carl
montana
If the wheels you have now are the adjustable width style, then yes, the later, triple loop style will readily interchange.
Think you mean wheel hubs and rims. Same spindle was used so if you use the wheels with matching rims and the correct wheel bearings it's no problem. Late M through 450 have a thicker rim bolt area than most all M came with so a little stronger. Different outer bearing and race were used on the last of those wheels. So the matching race and bearing needs to be used. Don't use a later race with a early bearing of vice versa.
See you have a wanted ad for wheels and rims for a M wide front. Information I give was for a narrow front.
Old style IH wide front with tie rods in front of axle use different hubs or wheels. Use H through 350 wheels on those.
