I just got a 1967 Ford 4000 Diesel. First tractor and many questions, I will start a new topic for each to keep to one topic.
I have downloaded the manual for my tractor but do not understand about the 8 speed dual lever transmission. When sitting in the seat I have left side a taller stick (High?) and right side a short stick (low?) I understand both have to be in neutral for the tractor to crank. But this is what I have, the left stick is very loose movement when in neutral, but the right short stick does not have near the slack or play when in neutral... is this normal?
The right short stick seem to go to only 2nd - straight up and Reverse straight back. I can not get it to go left = 1st or right and up to 4th. If it only has the 2nd low I may can live with it as I will use the tractor to drap the road and go slow.
I don't understand how the dual transmission works.
When I do use the short sick and put it in 2nd it does not go. I have to engage the left tall stick into a gear before the tractor will move and the same with the tall stick, if it is in gear and the short stick in not in gear, the tractor will not move. So it seems both sticks have to be engaged for it to work.... is this correct ?
Thanks
Michael
Thanks
Michael
