Geo-TH,In
I use this to weed eat where no mower can go. Clean around, over and on the other side of flower bed in gravel pit. Took about 2 hours. You need to have a loader with hydrostatics. You have to go very slow, especially around fences, trees.
At least that's a good way to keep your distance from that thing!
I have to mow the utility easement behind the shop. So rough a regular mower won't work. The gravel and sticks and whatever else gets picked up goes flying!
had to look at that a couple times before I think I understand what you built , good job ,,... it looks as though the lumber is crossed allowing a pivot on the clutch side,, allowing a breakaway for fence post ect .. also the loader capabilities should make this safe to operate around ponds that are not sloped too much ,, but it would have its limit
