Wes Verbal
So...... I've done just about everything to model b but have small problem with the clutch. I've been trouble shooting it past few days ? Every time you disengage it at idle speed hit makes s sound as if drive disc is hitting outer face pad? I've checked to see if it warped and cracked but nothing shows signs or this. The clutch is dry no oil inside .Noise is like rattle or rubbing noise as if it comes from outer clutch pad or in that General area? My IT Manuel says nothing about a clutch bearing, so don't really know much on that? Anyone have similar troubles ? as this? I've ordered all new outer and inner disc to replace to see helps...
