I have a 15 year old craftsmen garden tractor 22, kohler engine, model number 417.273090.
It will not start without a jumper from charger. Mower deck will not run again if turned off after running engine. Mowing deck will run if you let the engine idol for a minute or two then the mower deck will start.
We did the following
New stator (old stator wire black)
New rectifier ( We burned out old having it connecting when jumping engine)
New solenoid ( purchased from sears)
New battery ( had old battery tested it was bad)
New starter (old cracked)
Tried starting again solenoid makes a clicking sound tractor will not start.
Purchased the solenoid new from sears.
Replacement starter looks bigger, however fits the tractor.
Is the mower deck causing the starter issue now?
Sure could use some assistance.
All comments welcome.
Thank you for your time
