(quoted from post at 03:48:21 07/25/15)
hendersonmonte
Welcome to YT
If your 3020 serial number is below 123,000 you can attach FEL valve similar to these photos.
I agree with Bob that you need to check your FEL valve to determine if it's closed center. With open return hose aimed in tractor hyd filler hole,pressure hose attached to tractor with engine operating with both spool valves in neutral ""no oil should exit return hose".
pressure(in) connection
Thanks for the help, I have a "prince" valve, I pressured in and I thought returned out on other side, there is a larger plug that shows power beyond, I never taped into that one, so I need to check if its open or closed center. If its open, then what are my options? Thanks again
return(out) connection
alternate return connection
