Turn engine over till rotor points to engine block mark point on block.As you as you remove dist rotor will turn when rotor stops turning mark block again.This is where you point rotor when reinstalling
traper
The distributor is driven by straight cut gears so there will be no turning of the rotor as the unit is removed.
