Removing an external part from a Fuller Tranny
lenray
Have a 5 speed Fuller transmission in a 1964 tractor that has a geared shaft on the side that ran a self loading dirt pan scraper. It leaks and I have no use for it. It bolts to the underside and also to the topside of the tranny.
Any ideas what I will have if I remove. Probably was a cover plate at one time.
Thanks for any help ideas.
Tried to have a pic--will try again............
It's a PTO attachment. Simply remove it and install a blank cover in it's place.
I probably have a spare cover, if you don't have one at hand.
I can't tell, though, from the pix if it is the large type or small type cover.
That is just a common old PTO drive or axillary drive. Just drain the oil and unbolt the unit from the transmission case. That would be the flange with 6-8 bolts not the four you see behind the yoke. The brace going to the top is just under one of the top cover bolts. When you get the PTO unit off then you just need a cover for the hole. Just about any heavy truck repair place should have those covers around. You have to take them off to install a new PTO unit. Nothing special about a Fuller transmission PTO cover.
Here is one that is on Ebay as well.
<image src="http://forums.yesterdaystractors.com/photos/mvphoto24579.jpg"/>
Thank you Bob and Ronnie---the unit is about 9 1/2 x 7 and that is bolted to a bigger unit that goes under half of the bottom of the tranny and alway to the top measuring 16 inches long up and down.
Ronnie where did you find that on ebay??????
Like the others said you can find them laying around in truck shops that do like mount equipment to the trucks such as snow plows, etc. I will need to look here I have had one laying around for long time, I probably have several gaskets left to mount them as well. I could mail that to you no problem. J.
Search Fuller PTO cover. There are two on there right now. The "small" six bolt one and the "large" eight bolt one. They are a dime a dozen around anyone that mounts PTOs. Is there any one around you that mounts dump beds??? They would have them left over after installing a hydraulic pump.
JOHN S. on that other project; I found a new splined shaft and installed it in the Vickers pump. Filled the pump with oil and spun it by hand. It seized or caught the vanes. Tore it down and there is a very small hair line crack in the part called the ROTOR RING. Pump number VTM28604510
I am thinking the parts I need are the rotor ring, rotor and the vanes.
Looks like it is the VICKERS hydraulic pump cartridge kit 923092 , but I have been wrong before..........................
Any truck/agricultural wrecking yard should have those pto covers by the dozens. Only two styles of them since the '40's practically. And they were on all the manual transmissions in the chevy C50/65, Ford, IHC, etc.... should be easy to find.
