I just replaced an exhaust manifold gasket on an unstyled JD A. The 2 outer stud holes look like the go into the water jacket. I put hi temp anti seize on the stud only. Do I need to put pipe dope on it instead? Will it leak as it is?
It seams that the company wouldn't produce a tractor that would leak water out that hole. The hole covered is next to an exhaust gasket that you install dry with no RTV.
Thanks,
Robert
Thanks,
Robert
