I have a Ford 5000 with a single barrel hollie carb.
What is the measurement for the float. Any pictures showing it would sure be appreciated.
Tractor started this:
Ran good for an hour then acted like out of gas.
We did this:
Checked for gas in the carb bowl by unscrewing bolt at the bottom of carb. Gas was in the bowl.
Replaced plugs.
Found water in the coil replaced it.
Put sea foam in the tank.
Tractor started and governor started hunting.
We turned off tractor let it set for a few minutes.
Started tractor now it runs smooth.
I do not trust tractor carb. Got to get hay up if it stops this rain.
So we are thinking intermittent float sticking. This is why I am asking what to look for in the float?????
Thank you
All comments welcome
We did this:
Replaced plugs.
Thank you
