I've always wondered, when using any tractor with remotes for whatever equipment, is there ever any concern about what fluid might be left in the lines, cylinder etc, and compatibility with whats in the tractor ? If so, whats best to avoid mixing fluids if its a problem? Would you drain the implement lines or cylinders or something? I've used remotes on tractors at times, more so helping a farmer doing spring planting, hay etc. but he had new equipment, same brand as his tractors, just plug and play for the most part, except when the 620 had pressure on the remote for some reason, could never get the lines connected, til I figured I needed to release the pressure off it.
I had gotten to thinking about this after I received a newer tractor with 2 pairs of remotes, and never recall ever speaking about it with anyone knowledgeable of same.
