L 4350 Kubota split
Mtractor
Well I got it split and my throw out had locked up and messed up the bolts on my clutch fingers. I have ordered a new bearing . The little bolts I just went to a special bolt store that had them . Kubota does not just sell the bolts. My question is how much bolt do I leave sticking out for the heads to hit the throw out bearing?
You will have to find a service manual on that model of Kubota and it should give you the height that the finger adjusting bolt should be. I do not have any Kubota manuals so I am not much help.
Someone did not give you good information from KUBOTA you nee a kit Lever release # 32510-94070 will have the RIGHT bolts and pins with the instructions.
(quoted from post at 12:37:58 06/29/15) Well I got it split and my throw out had locked up and messed up the bolts on my clutch fingers. I have ordered a new bearing . The little bolts I just went to a special bolt store that had them . Kubota does not just sell the bolts. My question is how much bolt do I leave sticking out for the heads to hit the throw out bearing?
Like JDS says you need the manual to adjust the fingers. And like HoboNC and I say, if you are a big boy it is time to learn to measure how far back from the mating surface the clutch release bearing surface is, then adjust the fingers to 1/8 inch from that same point as measured out from the mating surface on the back of the block. You can even adjust it to closer if you want.
