farmall cub wiring
I rewired my cub with a new wire kit. The fan belt is not on the engine. When I hit the starter button the generator also turns. Along with smoke from the ground connection on the battery.I think I have the wrong wire going to the voltage regulator. Any help would be greatly appreciated.
Some of the cubs were neg ground and some were positive ground. Make sure the field wire to the generator is right. Go to Rudi's farmall cubs.com and that site has all the factory manuals that are downloadable for free.
Should have a wiring diagram.
this diagram is for H and M, but also same as cub, A, B, C
Note, yours may have had a wire from ammeter to light switch rather than L of reg. to fuse.
