IH C-135 Power Unit H-2006
sawnee25
New User
I have a Power Unit H-2006 that I need a clutch, pressure plate, and a throw out bearing for. I am having trouble finding what will fit in there or where to find it. Does anyone have any information or these parts?
More info would help, because I don't think the parts catalog is available on the CIH consumer site.
Is this an over center clutch, perhaps a TwinDisc?
Post some measurements and photos, I doubt it's gonna be real tough to find.
Also, check the Yellow Pages for a nearby clutch/brake.industrial friction shop. A place like that can probably easily match up what you have... my even have it on the shelf of be able to re-line yours.
Thanks Bob for the reply. I am missing the clutch assembly, threw out bearing, and the rod that goes threw the bellhousing and runs the threw out bearing. I will try to up load a photo
This is the Photo of the flywheel and bellhousing.
You will also need a Pilot bearing for the center of the Flywheel, and a throwout bearing carrier, as well as a pilot shaft for the throwout bearing to move back and forth on. The direct adapter in the center of the FW is hiding the pilot bearing. Jim
There used to be a clutch but my father put this motor on a welder/generator and took the clutch out. I need a new one because now I am putting it back in a tractor and need the clutch. Unfortunately, my father passed away. I have asked the local clutch mechanic and he said he could rebuild a clutch but we needed the clutch to rebuild it. He could not order a new one. I was hoping to find someone who new what this motor came out of or maybe even the size of clutch I needed or where to go to find one.
Thanks so much for your reply
(quoted from post at 06:22:33 06/21/15) There used to be a clutch but my father put this motor on a welder/generator and took the clutch out. I need a new one because now I am putting it back in a tractor and need the clutch. Unfortunately, my father passed away. I have asked the local clutch mechanic and he said he could rebuild a clutch but we needed the clutch to rebuild it. He could not order a new one. I was hoping to find someone who new what this motor came out of or maybe even the size of clutch I needed or where to go to find one.
What tractor are you installing it in?
It is an old Oliver cleat track with a loader. You may have been right when you said this may not have had a clutch in it
previously. Maybe I will need to get a new bell housing. If you have any thoughts please let me know. You have been a big
help so for. Thank you so much.
