What to make from Tractor Rear Rims?
Lanse
Hello there!
So a couple of years back I acquired a pair of manure spreader drive wheels, they look just like the rear wheels you'd see on a tractor, just a little smaller (I believe they're about 24" wide, without tires), and have stamped steel centers...
Well, I didnt end up using them unfortunately, and the tires are about shot (they have very bad and deep dry rot), so I'm wondering what I could do with the rims?
Thanks guys...
>inb4 make them into backyard fire-rings
I made this burning barrel out of 2 tractor dual wheel rims welded together
I'll tell you exactly. Locate your Boy Scout troop / Girl Scout Troop / possibly Cub Scout Troop, I'll bet they would love to have a fire ring for campouts.
Bench(weld a seat and back between them), hang them and hang something in the center, driveway markers, planters, table (make a stand under, or put a flat top across two), sculptures (manly as wheels), get your hands on a lot more then use as a open fence. If they are completely hollow in center they could be small fire wood racks(enough for one bonfire??).
I could go on but I'll leave it at basically just about anything that would look alright in that size circle.
