showcrop
I need some bolts that are about 5/8 diam directly under the head, then reduce to about 5/16 after about 5/8 inch. What do you call that type of bolt
Yes, you are asking for a shoulder bolt. If you want to go from 5/8" to 5/16" it will probably snap off where it changes diameters.
If I needed to do a similar application I would use a grade 5 or grade 8 5/16 bolt with a spacer sleeve around it to get the 5/8 diameter.
