sunsettractor
I was out playing on my 300 Utility, overall a pretty solid and very handy tractor. Engine just started missing, first thing I did was pulled spark plug wires one at a time and found the guilty cylinder. What is strange is that when the plug wire is firmly pushed all the way into distributor cap, engine misses, if I pull the wire completely out of the cap, the miss is the same. Then... If I hold the wire close to the distributor cap so that the spark jumps across, the engine smooths out and miss goes away. Push the wire firmly into cap and misfire comes back. I installed a new set of plugs and wires, gapped points, the cap looks new inside, no obvious wear or cracking, no difference at all. Is there any one thing that would cause this? Any help here much Appreciated...Tom
