Help International 1256
BradyW
Replaced O Rings from oil pump to Oil Cooler tube was given new (Black) seals, put all back together but it is still leaking a little, at oil pump end , wonder if their are better seals available the old ones (pink) and soft. What are my choices speed sleeve?? Any Help would be great.
I'm thinking I read that someone found that to get them to stop leaking they switch from round o rings to flat o rings or flat to round the opposite of the original! Sorry all I can say to help
Check the bore where the o ring seats. Over the years vibration will wear a grove where the o ring seats. The red o rings usually work better. Have made some seal by wrapping some tefflon thread tape around the end of the tube where the o ring seats.
My '12' leaks there too.After several attempts to fix,it still leaks.I finally 'gave up' and let it leak.....
