Timing marks
Tresler
New User
I have a 464 international tractor with a 179 Diesel engine the seal went out in the injector pump so we pulled it off and replaced the seal but while pulling off the pump my father loosened the three bolts on the gear and now the engine is out of time I need the timing marks to be able to get the engine back into time
Find the front pulley marks per the service manual, then find the pump internal cam plate mark on the edge under the two screw cover plate on the pump side. Most German diesels were either 14 or 16 degrees BTDC on #1 compression stroke, that's where the pump mark needs to be locked in place.
Thanks I know I have to get #1 stroke up but I don't have a manual so that's why I'm asking to see if anyone knows what the timing marks are I see the pointer on the balancer but I don't see any marks and what are the marks in the inspection cover on front of engine
