Geo-TH,In
I have an old Noma riding mower from TSC. It older than dirt. It has all 4 wheels in
a grave, just haven't covered her up you. This old girl has a v twin 16 hp vanguard
briggs. It runs fine for her age. Tenant calls and says something is wrong. It would
start and run just fine. When you apply power to the electric mower clutch, it shut off.
I removed the shroud, discovered one cylinder was choked with dirt. I found the kill
wire to the two ignition modules. Started engine, turned on the mower clutch and problem
solved. Turn key off, 2 seconds later the solenoid in carb kills engine.
Now which safety switch is bad?
