New Holland L553 skidsteer
Cas
I have a New Holland L553 skidsteer. Hydraulic Interlock is not getting power. Can someone tell me how to bypass it? Would like to lift boom to work on it.
On mine if the switch under the seat gets unplugged the boom will not raise but the bucket will still tilt. There are 2 plugin, one on the switch and one on the pig tail coming off the switch
I forgot to add find the pigtail in the cab and run a jumper wire on it to see if it will work. FOR SAFETY REASONS DO NOT RUN IT THIS WAY just use it to check the swich
I had several 785s over the years... the electric safety system had a control box on the right hand side. on the bottom side of the box was a very small toggle switch. The switch could be put in a "test" mode, that allowed a temporary override of the safety system.
I'm guessing the 553 (same vintage) was similar.
