(quoted from post at 13:26:03 05/30/15) I like to double nut them after heating around
the stud, then rap on the end of the stud with a
hammer a few times. Quite often that will help
even with no heat, just have to hit it square on
the end. If you do all this and don't get one out,
and accidentally DO snap one off in there, just
use oxy acetylene torch to blow remainder of
stud out of the hole. The stud will always melt/
cut out of the hole before you melt the cast iron.
Also is much easier if you drill a hole 1/4" or so
through the stud before you use the torch, it
takes less time to pierce it out of there. With a
good dark shield, you can look right in the hole
and see the threads appear as the stud melts
away. Usually have to stop and chip slag out of
the hole a couple times before you are done.
Run a tap through down the hole, insert new
stud with anti-sieze, done. Most people are
afraid to try it, but it works very well. I used to
do this all the time removing broken lower roller
bolts on dozers and excavators. Some through
holes, some blind holes, most in steel track
frames. Had 17 broken bolts on one side of an
excavator that had been broken forever that I
had to take out one time. Good luck
Ross
(quoted from post at 18:36:53 05/30/15) didn't read all the replies but multible heating and cooling is best and the faster you cool the better
(quoted from post at 00:25:45 05/31/15) [b:aa9be63ee3]Why let them cool? [/b:aa9be63ee3]Get 'em red hot and grab 'em with a Vise Grip. Hot bolts come out as easy as a hot knife cuts through butter. If they start to get hard to turn, apply some more heat.
(quoted from post at 17:08:27 05/30/15) I have had good success also using the cutting torch to blow out broken studs in cast iron, never tried it in plain iron. it may be a little more tricky. The hole first is a good idea. stan
(quoted from post at 15:38:56 05/31/15) One difficulty that I have found with this method is that the molten metal from the stud blows right back onto and into the torch head. Found it to be just a bit rough on torch tips. BUT.....it surely does work!
