hat does your owner's manual tell you........Ford knew better than some unknown Jake-the-poster! :roll:(quoted from post at 11:26:45 05/18/15) Saw some controversy about the oil weights in Ford auto engines.
What are your experiences with this?
Ron
(quoted from post at 06:45:09 05/19/15) Do what the owner's manual tells you. In 2009 I bought a new Ram Hemi with all the HP and torque. Manual said use 5w-20, not 30 as it had the 4 cylinder cut out system when you didn't need all 8. For an old 15w 40 guy in everything, that was real hard to swallow. The manual said that the system would be unreliable with 30 and that the oil pump was designed for 20.....................so use it!!!!!!!!!!!!!!!!! Yes sir! So I did.
(quoted from post at 09:26:45 05/18/15) Saw some controversy about the oil weights in Ford auto engines.
Ron
