Goose
Went to use my acetylene welder this afternoon and could not get a strong flame. I wanted to do some brazing with a #5 tip.
I just replaced the acetylene bottle last fall and hardly used it over the winter. When I open the valve on the bottle, the gauges read 200 lbs., regulated to 5 lbs. like I usually have them set. As soon as I open the valve on the torch both gauges drop to zero. I can only get a weak flame out of the torch.
Does this sound like I have an empty bottle? Usually when the bottle is empty, the gauges don't go up at all when you open the valve on the bottle. Or do I have a problem with my regulator? This unit is 40 years old and has never had any service work done on it because it's always done what it's supposed to.
Any suggestions?
Any suggestions?
