37chief
- Location
- California
Last week I mentioned I had severe front end wobble when applying the brakes on my Dodge. I removed the tire. The rotor had no run out. and looked good, no marks. So what to do? I bought two new rotors. The rotors and the wheel hub are one unit. When I opened one box I found the pickup ring for the ABS missing. I took them back. I just installed new pads and put everything back together. The only thing I did find was one bearing just a little loose. I snugged up the bearing. A little over 100 mi. so far, and no wobble when applying the brakes. I think someone mentioned wheel bearings last time, may cause wobble. Time will tell. Stan
