John Deere M sunshade
EBlaich
New User
What kind of sunshade would you guys recommend for a john Deere m I'd like opinions for the hot tractor show parades work days and cruises thanks everyone and keep the vintage iron Rollin
You can reproduction ones at http://www.tractorumbrellas.com/ They will set you back a bit more than the generic ones.
Thanks for the input guys im looking at the traditional styles but not sure on mounting and clearance.
They are a PITA.
I rarely use mine - knocks your hat off - tree branches are tougher than the umbrella.
Mine is on the tractor only for photo-ops with the grandchildren.
As you're most likely aware, the M is not the easiest tractor to get on and off of. In considering
your question and knowing my mount/dismount technique (where for a moment just before sitting down
I'm standing essentially upright on the axles just in front of the seat) I would have to have the
sunshade WAY up high to prevent smacking into it. The way I do it I would also probably hook
myself on the support when I swing my leg over the tire. I don't know your technique but I'd
suggest constructing a test sample out of broom handles, cardboard, and duct tape before making a
purchase to make sure it isn't too much of a nuisance.
